dougrainer
Jun 05, 2015Nomad
On your model, the doors pop off the hinge. Spray a lot of WD 40 on the existing hinge and channel. Open the door about at a 30 to 40 degree angle. Take a mallet and POP the bottom edge of the door inward towards hinge. the door will pop out of the door frame. Spray WD 40 on the hinge rail of the new door. Install the door under the frame hinge rail and center. Holding the door at the same angle as the one you took off, take a rubber mallet and from the inside out pop the door frame into the hinge rail. |\ Doug
38,709 PostsLatest Activity: Mar 12, 2025
