phnguyk
Jul 24, 2013Explorer
dougrainer wrote:FIRE UP wrote:dougrainer wrote:
If you have a dual pane and install a single pane, the window will rattle. Doug
Well Sir,
I'll have to disagree with you. And to the OP, YES, YOU CAN REPLACE IT WITH A SINGLE PANE WINDOW/GLASS. I know 'cause we did it. Our '99 Fleetwood Bounder, 34V on the F-53 Chassis and V-10, developed fogging in all four, forward windows. Both the sliders and the stationaries on the passenger and drivers sides. So, I went to a friends glass shop and we discussed changing them out to Single Pane windows. He said: "No problem".
What we did was install "Laminated" glass in place of the Dual pane window glass. The Laminated that we used was equally as thick and, even had the same exact, "built-in" window tint as the rest of the coaches windows. All he had to do was install the correct window channel/butyl rubber that held it in place to the original window frame.
Now, here's the kicker. I was told I'd get some serious wetness and sweating on the inside on that new glass. There was never, ever any sweating or, extra loud noise or, extra heat or cold due to the lack of the insulation factor of the original windows. Nope, never happened! Those new, Laminated glass windows worked flawlessly.
But, here's some advice. The cost was very, very close to the same as it was going to be to purchase new dual pane windows. But, the true benefit was, NEVER TO HAVE THEM FOG AGAIN! Would I do it again, yep, in a heartbeat. Your choice.
Scott
I base my statement on EXPERIANCE with both single and dual pane windows as a TECH that sees all kinds. Single pane windows have a tendency to rattle more than dual pane. I have had LOTS or arguments with various OEM's that install driver and pass side single panes and the customers that complain of rattle. Installing a single pane in the same width as a dual pane will cause MORE rattle/noise unless that single pane makes up the thickness of the dual pane. Dual panes are heavier and fit tighter and hence they do not have as many rattles as single pane windows. Doug
Not a very good TECH if you install glass without the proper sized gasket, that's just not smart. Also it's not the glass rattling it's the screen when air pushes through the thin gasket that allows the windows to slide pass one another. The glass cannot "rattle" as you say, unless the gaskets failed or are failing. Argue all you want you don't make any valid points. So your last sentence is not true, and dual pane's do have more failures. I never had my single panes fog on the inside, or etch on the inside
Btw I'd rather fog I can wipe away, then fog I can't. And i'm in the NE and camp in the winter.
