donn0128
Aug 22, 2017Explorer II
Here is one
If this is a 4/5 wire configuration, then Hunter Douglas has a decent one for around 25 bucks. Since most home thermostats are 24V and your RV is 12V you will either want a dual voltage or battery powered one. There are several places on the web that have wiring schematics for connecting to an RV. The HD will need the addition of a small SPST switch to get both hi and lo speed AC fan settings. Following the instructions you should be able to do it in an hour or so.
