olfarmer
Sep 01, 2018Explorer II
tropical36 wrote:Stim wrote:
So the airbags have lasted 18 years and now you want to change suspension parts?
With the airbags you have some height adjustment, ride comfort.
Bags are a pain to change(plenty of tips on line on changing) but much less than springs.
Thing is, once aged and fatigued, you have to change the springs anyway and if continuing with those PITA bags, then OEM coils. Otherwise, you'll never get the proper ride height of 1 1/4 - 2 1/2" for alignment, let alone any real suspension travel.
Continuing with the bags, requires daily checking of the air pressure, while on the road and if one should be lost, then you'll be replacing same in a CG somewhere or be looking for a shop somewhere along the way.
I agree, thanks for your excellent explanation of the situation! As my motorhome sits, with no air in the air bags. There is almost no space between the bump stops ( a little more on one side than the other) so the springs are obviously weakened and worn out.
38,782 PostsLatest Activity: Sep 10, 2026
