tropical36
Sep 02, 2018Explorer II
olfarmer wrote:
Thanks Tropical36!
I weighed it today and the front axle was at 5440 lbs without my wife on board, she weights about 120 lbs so I thought I should add 100 lbs. The gawr on the front is 6000 lbs fully loaded. I think I will tell Hendersons that it weighs 5540 lbs. Does that sound reasonable to you? Other than the wife and a couple variables the coach is fully loaded.
The absolute min. would be with the SS265's but I'd probably go with these 268's ..... SHOWN HERE
Have a talk with them, before ordering and yes, you must include the wife or anyone else that might be riding up there, including yourself and a 300lb buddy, so again, would lean to the higher limit.
If I remember correctly and with going a little high, the ride height, was still not at max. and that was after removing the Helwig buggy spring of about 50lbs that wasn't factored in.
Also keep in mind that with near empty fuel, freshwater, grey and black tanks, some of this weight could go forward or at least in theory.
38,782 PostsLatest Activity: Sep 10, 2026
