brocja01 wrote:
I'm looking at those rolls of 5050 LEDs, can you simply cut them to length and wire them in? Could you guys post some pictures?
Yes, you can cut them to length about every 2" with a pair of scissors. They have soldering pads that are clearly marked positive and negative and all you have to do is solder the incoming 12 volt wires to those pads. I put four strips in each of my lights so I had to wire jumper wires between the strips. You can fold and turn the strips but I preferred to solder jumper wires.
