Sam_Spade
May 04, 2016Explorer
wa8yxm wrote:
and being "Sealed" and maintence free you can not replenish moisture that eventually boils off, this means they may not last as long as a properly maintained flooded wet cell.
That does NOT happen in normal use. The hydrogen and oxygen produced recombine back into water inside the battery.
You can force that to happen if you abuse the battery however......like applying a charging voltage that is WAY too high and leaving it on for a long time. That usually doesn't happen though.
For those folks who want to install batteries and then pretty much forget them, AGMs probably are the best choice even considering the extra cost.
38,769 PostsLatest Activity: Mar 31, 2026
