Empty_Nest__Soo's avatar
Jun 12, 2019
Replacing older mirror
I need to replace the driver-side mirror head on our 1997 Safari Sahara. (The original mirror head got clipped by a truck, which did not stop.) The 22-year-old mirror was made by Velvac and is what they called their Superstar mirror head. It’s 13 inches by 8+ inches, rectangular with rounded corners, not tapered at the top like newer models. The mirror head is out of production and I cannot find one in any of the major salvage yards. I therefore have in mind replacing both mirror heads and keeping the original bus mounting arms.
Speaking with Velvac technical assistance has been an exercise in frustration. All they seem to want to do is sell me two complete new mirrors. Never mind that the mounting holes in the new bases do not match the holes in the coach facing.
Has anyone replaced a 1990’s-era mirror head with a newer head on the original mirror arm? What problems did you need to overcome?
My mirror has 5 wires in the 6-wire plug, which looks the same as the newer plugs on 5-wire mirror heads. Can anyone tell me if the wiring pattern is the same, or will I have to puzzle out which new wire mates with which old wire?
Thanks!
Wayne
  • Did you get the mirror part number off the bottom of the housing? I found an exact match to that number on Amazon for under $200.00. Velvac wanted $281.00 for it.
  • Try Northwest RV supply in Eugene, OR. 1 866 678 7467. They used to buy all of the surplus parts from Monaco. I have bought many parts from them that no one else had, specific to Safari/Monaco.
  • I have no idea what to tell you, but have straightened the head and took it to a glass company?
  • Also got clipped by semi. found replacement on Amazon for less than $300.00
  • Ivylog's avatar
    Ivylog
    Explorer III
    I’ve bought several pairs off of EBay...very reasonable.
  • I should have mentioned . . . I've been trying salvage yards all around the country for a couple of months. No luck.
    I hope to be able to mate a pair of new heads to the arms I have.
    Wayne
  • There are several RV salvage yards around the country. I would contact one of them and see if you can get a replacement off of a similar RV. Just do a search of RV salvage yards and find one close, altho the shipping will not be that bad if you can't find one close.
