JoeH
Feb 24, 2020Explorer III
I had broken gears in the gear case too. Take a look at the gear case bushings and the potmetal case that the bushings are pressed into. On mine, I found the bushings to be OK, but the potmetal case had wallowed out thus causing misalignment of the gears and tooth breakage.
