dougrainer
Mar 29, 2018Nomad
The 15K pulls about 1.5 to 2 amps MORE than the 13.5k. Regardless of what you have done in the past, running a 15k and a 13.5k is NOT advisable on 30 amp service. The 15k pulls about 14 amps and the 13.5k about 12 amps. That puts you at 26 amps BEFORE you add in the refer(2.5 amps) and the Power Converter (1 to 2 amps) and any other 120 appliance(coffee maker/ kitchen cooking appliances/ ANYTHING else that needs 120 power. While you have done it, I will bet the 50 to 30 adapter, the 30 amp pins show heat and wear. Doug
