valhalla360
Mar 29, 2018Navigator
I wouldn't bother to swap them out if it's just to upgrade but if you are replacing anyway the cost difference should be small, so sure.
As mentioned, two on 30amp is questionable regardless of BTU rating.
The 30amp outlet is actually only rated at 25amp continuous, so while it may or may work, there is a good chance of overheating wires and connections. In a worst case scenario, it could lead to a fire if the breaker doesn't trip.
