theoldwizard1
Mar 29, 2018Explorer II
dougrainer wrote:
Regardless of what you have done in the past, running a 15k and a 13.5k is NOT advisable on 30 amp service.
That is a VERY BROAD BRUSH statement ! I certainly would NOT condemn running 2 A/C units on 30A, assuming ALL of the wire is in tip top shape. Check the specs. Newer A/C ARE more efficient (draw less current).
You might need to install Micro Air Easy Start units on both to reduce the start surge.
