pianotuna
Mar 29, 2018Nomad III
Are you suggesting that there is something "special" about the #10 wire used in the shore power cord of an RV. That it is somehow "exempt" from a continuous rating of 80% (3 hours). BTW that is 24 amps, not 25.
I've had 30 amp cord ends melt with a 15 amp shore power supply. The culprit appears to be low voltage. The "ends" that failed were 30 amp female Cameco. The male Cameco seem to be ok but the females burn up easily.
dougrainer wrote:
Please reference any codes or NEC your statement that an RV 30 amp PLUG and 30 POWER CORD is only rated at 25 amp continuous. We are talking RV wiring, not regular home circuits. They have designed 30 amp RV's for over 45 years and in 38 years as a tech, I have NEVER heard the 25 continuous running as it applies to RV's. I have seen and heard it on various forums, but NEVER from an expert, just posters that heard of this from other sources. Doug
