Octaneforce
Oct 13, 2018Explorer II
rgatijnet1 wrote:
You can buy shower pan material at Home Depot that can be cut and shaped to any size. Then you can use whatever material you want to make the base. Even tile if you want to. For the sidewalls I would recommend the lightweight plastic 4x8 sheets that are also available at Home Depot along with the trim pieces that go with them. These plastic panels, along with the corner trim, should make a waterproof show enclosure. The base could be built up with wood and then covered with fiberglass cloth and resin if you do not want to use tile.
Ughh i was trying to avoid those white sheets at home depot. We have a shop bathroom that we redid with that stuff and it does the job but its just...cheesy lol. Regardless it looks like im gonna have to do this custom. I am not a good carpenter by any means thats why i was trying to find the premade inserts. If i made my own shower base out of fiberglass it would look like a 7 year olds paper machey project.
I think a tile shower base would be a good idea. Its a small shower so it wouldnt weigh too much. And the walls would have to be the sheets like you said
38,780 PostsLatest Activity: Jul 04, 2015
