TechWriter
May 31, 2013Explorer
MustangGT wrote:
I wonder which option, the self-leveling caulk or the tape has the best durability? the factory used the caulk on my roof stuff.
I used them all . . .
After removing the old skylight & caulk, I applied butyl rubber caulk (Surebond SB-140) in a continuous bead under the skylight. This is what Newmar recommended.
Then after screwing down the skylight, I put Dicor over each screw. When that cured in a day, I put Eternabond along all the edges of the skylight.
38,782 PostsLatest Activity: Aug 31, 2026
