msmith1199's avatar
msmith1199
Explorer II
Sep 01, 2013
Replacing the plastic parts on the Roof
My motorhome is about 9 years old now and thanks to the California sun all the plastic parts on the roof are starting to fall apart. Estimate at the RV dealer was $1500 to replace everything. So I figured this can't be rocket science so I decided to give it a try myself.
I'm doing things several pieces at a time, but what I have discovered is it is not nearly as difficult as I would have thought. The only hard part is you have to get up on the roof and work on your knees, but otherwise the things are fairly easy to replace. The roof vents for the toilet and drains were all fairly easy. I used my oscillating multi tool to remove the old sealer and the vents just unscrew. The multi-tool does a great job of cleaning the old sealer off and making a nice clean surface. I have a fiberglass roof which makes it easier. I would think a rubber roof would complicate things. The screw holes on the new vents never line up so I drilled small starter holes, put a putty gasket on the new vents, and just screwed them back in place. Sealed them with self leveling sealer and those were done.
I went to Camping World to get a new plastic vent cover for the bathroom vent and instead of spending $20 I ended up spending $200 and got a Fantastic Fan Unit for the bathroom. Removed the entire old vent assembly the same way as described above, hooked up the wires from the old fan to the Fantastic fan, made sure it worked, and then applied the putty gasket and screwed it back in place. Probably about an hour work total. I haven't yet sealed it because it started getting too hot on the roof. So as soon as it cools down this evening I'll get up there and seal it.
I'm glad I decided to do this project myself as I learned a few things and I paid close attention and made sure every possible path for a leak was sealed. I had sealed up roof leaks in the past I they were all caused by the workers at the factory just not doing a good job. For example my shower skylight leaked and when I went up to fix it I found about a half inch space that had no sealer on it. I don't make those same mistakes when I'm doing the work myself.
  • So glad for you doing it yourself. I receive pleasure knowing when I'm done working on mine it is done right.
    I found couple small cushions at a junk store for my knees and over hood of cars.
  • I didn't even think of painting them. That's not a bad idea for the plumbing vents, but I can't paint the Fantastic Fan covers or the Shower Skylight. I guess I could, but that ruins the skylight effect of them.
    One thing I did notice is there are different types of these plastic parts available. On the plumbing vents there were some really thin plastic ones and some really thick plastic ones. The difference in price was only a couple of bucks so it was a no brainer to buy the heavier ones. But the ones that were on the motorhome were the cheapest thinnest ones. Clearly the factor works to save pennies anyplace they can.
  • Shortly after the purchase of our MH in 2006 I painted all the plastic parts on the roof with paint that had UV protection in it. Found a paint color very close to the main body color which looked good. 7 yrs later and no problems even after spending 5 to 6 months a year in Fl. each winter.
    KDK
  • TechWriter wrote:
    Good for you. I did a similar thing to my 12-year-old Class A. When I replaced my plastic fridge vent cover, it came apart in my hands.
    Mt fridge is in the slide so I don't have a fridge vent on the top, but basically the plastic other vents did that on mine. They were very brittle. Went camping last weekend and after we set up I went into the bathroom and noticed the overhead vent was open. Upon closer look it wasn't open at all, it was just gone. Most of it was gone, there were still a couple of pieces left. I figure that meant it was time to get this project started.
