wa8yxm
Oct 10, 2019Explorer III
I went the other way.. No difference in the flange. No adapt-a-kit needed with one small exception
The Fresh water side the hookup is different... How I modified mine
Added a shut off valve (1/2 inch IPT to compression fitting)
Used a flex hose (1/2 inch one end. Compression fitting the other matching valve)
now I can shut off the water to the toilet without shuting off entire RV if there is a problem (Yippie)
