- blakduk01ExplorerTwo years ago I replaced all 6 of my michelins witha 6 TOYOs. Cannot say enough good about them. Smoth ride, quiet, and inexpensive.
- AOCRETIREDExplorerput 6 11R33.5 AH12 load range G's on coach 8000 miles ago, GREAT ride, quiet and we are very happy.
- imgoin4itExplorerI put new 275/70/22.5 Michelin tires on our coach about a year ago. I looked hard at Hankook tires. Not sure I got totally correct info. But I run 100psi in my front tires based on 4 corner weight and the manager checking the Hankook chart said I would have to run them at 130 psi. Told him max psi for wheels is 120 psi. He tries to convince me that 130 was ok and kept pushing Hankook tires. Have friends that are happy with them but I put Michelins back on. Better safe than sorry. Just check every thing before you switch tires.
- Dog_TrainerExplorerI put the Cooper Roadmaster tires on this year they replace the sumitomos I had for 6 years. I have put 1500 miles on this year and plan a 5500 mile trip this fall. So far they out handle the Sumitomos.
- J-RoosterExplorerI have a tire designed for RV use on my coach there Michelin XRV's, they are the softest rubber tire made for RV's! Michelin designed them that way because RV's do a lot of sitting. I got 10 years of use on my first set of Michelins and I'm on the 2nd year of my current set of Michelins! The tires that you inquired about are good tires, but they are a hard rubber truck tire. Good Luck to you in whatever you decide to buy!
- oldchief7155ExplorerI put Sumitomos on my Meridian and they give far super ride, handling, and less noise than the original Michelins for about $1,000 less.
- showdogmomExplorerYour tire size is exactly what we need. Currently have Michelen but RV is 8 years old and we really need to replace, in spite of fact it only has 10,000 miles on it. Thanks for the input We also have a Spartan chassis.
- purplekeenahExplorerShowdogmom, I put (6) 275 70 22.5 Hankook AH-11 tires on my rig about 20K miles ago. They replaced the GoodYear 670 tires that I had some issues with (slit in a sidewall, and herniated appearance on another tire), plus I thought they rode hard.
The results were three-fold - great ride, quiet, and price! On my Spartan chassis they work just fine, they may do the same on yours. - IvylogExplorer IIIIn 10 years I' ve never read a negative post about Hankook truck tires. I put 6 of them on the back of my MH and after 7K miles I still like them even though I have a different MH than most, I 'm heavier than most so I run more air than most. Despite all this I still bought them.:S
- sdianel_-acct_cExplorerwe bought B F Goodrich ST230's for our Class A Country Coach. Load range H.
B F Goodrich is owned by Michelin and the tires are made in the USA. We have put over 50,000 miles on them and are very happy with them. Much better than the original Toyos we had.
38,766 PostsLatest Activity: Jan 10, 2026
