RayChez wrote:
If the toilet holds water, then you do not need a seal. Before you start on any trip on your coach fill up the traps on your sinks, kitchen and bath and run some water through the shower drain, also your washer. It will stop your smell that is venting through the traps.
I would also recommend Happy Camper to eliminate all odors even when dumping. Best thing I have ever used. Do not use the blue stuff they sell at Wal-Marts and some RV stores. That just camouflages the smell. Happy Camper dissolves the solids and turns it back into water. It is an enzyme that eats it up.
At this point I've narrowed it down enough that the seal at the toilet flange is the leading culprit. Even though the bowl holds water, I think the sewer gas is either coming through the point where the toilet meets the floor, or where the "seat" part of the toilet attaches to the base...there is a lip there that may not be air tight.
It is definitely coming from the black tank, and it definitely seemed to be coming from somewhere very close to the toilet not the drains or from under the sinks. I had leaky air admittance valves at one point and I am very familiar with the grey tank odor. This was definitely black tank odor.
