Calamity's avatar
Calamity
Replacing towing hitch
I have a 2012 Thor Freedom Elite 24'and the hitch is rated at 3500, I need to hauls 5000 lbs. Where do I go to get my hitch replaced? Camping world hasn't gotten back to me. I am planning on hauling my 2 horses in their trailer.
I bought the RV the end of summer 2016 and I am so looking forward to camping with the horses. I will actually have a bathroom. (Hooray)
Any information would be helpful.
  • I use a weight distribution hitch with a sway bar.
    I haul antique tractors and our car, not at the same time, behind our 24' mh, now replaced with a 27' mh. Using the above type hitch.
    Dusty
  • Hi Calamity,
    As someone else had mentioned, the 3500 pound hitch you have on your motor home today might be limited to that weight because the chassis frame or frame extension could be limited to 3500 pounds.
    In general, Sprinters made since 2009 (maybe a year or two earlier) are equipped with a 5000 pound hitch so hopefully any hitch company could simply unbolt the 3500 pound hitch and bolt on a 5000 pound hitch.
    One thing certain about Sprinters and Transits. Frame extensions and welding & drilling of any kind is not permitted. RV manufactures are limited to work with what it is and they must use the existing holes for bolting a hitch. The reason is they use an exceptionally high strength but very thin steel that the heat from welding weakens, and the drilling of holes compromises. They shape the steel into a box frame to further get the strength needed.
    If your 24 foot long 2012 Freedom Elite is built on a Ford E350 or E450, or it is built on a Chevy/GM 3500 or 4500, I think the right outfitter can help you. Rust can interfere and sometimes nix the project, but your rig is only 5 years old so I doubt that would be a factor.
    One thing you will want to ask about is the addition of a rear trac bar, and replacing your stock rear stabilizer bar with a heavy duty version to stabilize your rear end while towing a multi-horse trailer. Most 24 foot motor homes are built on a standard 158" wheel base which means your motor home has significant rear overhang, the amount of house that hangs beyond the rear axle. The cantilever condition while towing a horse trailer should get those two upgrades for safe handling.
    I would call Champion Frame Align in Elgin IL below. I endorse them because they did wonders to the suspension of our motor home. Actually both the motor homes we've owned during our lifetime. They upgrade suspensions on everything from class C motor homes to class A's to school buses, Greyhound buses, ambulances, fire trucks, tractor trailers, just about anything with 4 or more wheels. They really know their stuff and are well equipped to handle anything. I believe they do hitches too.
    I know you live far from Elgin but it is surely worth a call. Maybe they can recommend someone much closer to you.
    864 Bluff City Blvd.
    Elgin, IL 60120-9519
    847-742-9294
  • Ivylog's avatar
    Ivylog
    Explorer III
    I do not find a 24' model... 23' Sprinter and if this is what you have, you cannot just change the hitch (it's not that simple) plus you will be grossly under powered.
  • You want to go to a business that actually install trailer hitches, that specializes in welding and metal work. I did a quick Google search: Chicago, Il, trailer hitch install and it returned 304,000 hits! So there are places in your area that install hitches. Look for a welding company that installs trailer hitches. They are out-there.
    I would not wait on Camping World any longer. If they couldn't give you the information you needed upfront and negotiate an appointment right away, then go somewhere else. And by the way, the BEST welder hitch servicers I've found are the mom-and-pop shops, and NOT the big bang organizations.
  • DrewE's avatar
    DrewE
    Explorer III
    I'd look for a local truck spring and chassis shop. You may possibly need to have some reinforcement done on the frame as well as replacing the hitch. You also ought to take care to make sure you don't overload the rear axle due to the tongue weight, which can sometimes be a pretty tight limitation on some class C's.
  • First, you need to make sure of the towing capacity of your RV.
    Second, give UHaul a call.
