Executive45
Mar 30, 2021Explorer III
Depends on your water preference. That is a two stage water filter made by GE. Easily replaced but takes some patience. Whether you keep it or not, you'll have to fiddle with it. The fittings are standard 1/2 inch so you have several choices.
1. Cut the screw fittings off. Get two 90 degree shark bite fittings and a short piece of PEX and connect all of them together.
2. Buy a two stage replacement filter assembly and change it out.
Obviously the second choice is my preference. You'll have to do your install under the kitchen sink which will be just as much of a nuisance as doing choice two, maybe more. There's more to water than just drinking. Sediment etc gets in your sink faucets and gums up your washer.......Dennis
Replacement 2 stage water filtration system
