JCat's avatar
JCat
Explorer III
Sep 07, 2022
Resealing Fiberglass Roof
Hello RV'ers.
My rig is 18 years old and I need to reseal the seams on the roof once again. I have seen companies that will seal the seams and recoat the entire roof, and it looks great.
I have seen a few spider web cracks in the roof so i am wondering if I should do this ?
Is it the correct thing to do and have you done it with what results ?
Thanks
  • Ok, I'm a bit puzzled.
    As long as I've been on these forums, I have heard some folks say that they would only get an RV with a fiberglass roof and that they WOULD NEVER buy a rig with a rubber roof. The reason being was the extra maintenance required with a rubber roof, that they only last "X" years, yada yada.
    Our rig, with a rubber roof, is about the same age as JCat's. I've sealed the original seams with Eternabond as needed over the years and generally just kept the roof clean, inspecting it Spring and Fall. I don't think it'll need to be replaced in the near future, but who knows?
    So, I'm surprised that a fiberglass roof needs this type of attention after a similar time period.
    Is this type of deterioration unusual for fiberglass roofs?
    An inquiring mind would like to know. :)
    Thanks,
    ~Rick
  • Its just like a boat. Once you get the cracks, the only way to proper fix it is grove the line cracks and then clean and wash very good. Then Resin and gel coat over. Should last many years. If you don't fix now water will get threw them over time and a bigger issues down the road.
    You might ask about replacing with a new panel or clean and glue down a rubber membrane over the panel. Look at the cost each way.
