First, and most importantly, thank you all for your helpful information. The following may be helpful in my quest to make the Aladin work. I have power to the Aladin as indicated by the red light on the Aladin dash controller. The dash monitor screen also works as the back up and side view cameras work on the unit. It seems like the Aladin is not able to communicate with the monitor. I am not able to get any type of information from the Aladin to display. My Monaco owner's manual says that there is a reset switch, in a cabinet, that will reset all of the Aladin information. It says to use the reset switch if the Aladin doesn't work. I can't find this switch. I am going to review the user's guide that was sent to me by Doug Rainer from Carrolton to see if that helps. Other than the Monaco's Owner Manual, I don't have any information specific to the Aladin, except what Doug just sent me the link to. If any of you want to discuss this off line, I can be reached at 214 437-3734. I am old and retired, so call anytime! Thanks so much!
Phil
