- tropical36Explorer
nyrngrz wrote:
Ivylog, which Whirlpool model fridge did you replace your Norcold? My problem is that I have the furnace under the Norcold 1200 and that reduces the height I can install. Not sure of your coach, but if it is only a 1/2 inch difference it may be able to work.
Same problem here and if and when we're ready, I may have to look again and into one of these... FISHER PAYKEL
Expensive, I know, but then DW wants a large fancy one, if ever, but as far as I'm concerned a little apartment size would do and would still provide more cu ft, than the 1200. Would also provide space on the side for an additional built in pantry. - Mickey53USAExplorerInteresting Read - Going to replace our Norcold next week with a Samsung RF18. I have a side entry and have 28 inches, so I am good to go. Have to modify the cabinet - bottom cabinet drawer is going out, but we will have a great refer. Installing a new PSW just for the refer as well as a Magnum AGS.
- tinkererExplorerWe did the same installation on a 2007 Discovery. There are 2 frames on the entrance door. You only have to take off the inside frame and move the passenger side seat. The peg for the door latch was in the way but we were able to lift the Samsung above the peg from off the bed of a pickup with some extra help. One of the best improvementselection we ever made. We have 4 golf batteries and they seem to do the job. My coach had two receptacle behind the old Norcold and I was pleasantly surprised that one of them was hooked to my inverter. I can email you a picture of the final installation.
- allbrandautoExplorerinstalled ref. Saturday tight fit but it went thru door
- TinstarExplorer
- IvylogExplorer IIINot on puter so do search Whirlpool DIY by Ivylog... pictures and model #s.
- nyrngrzExplorerIvylog, which Whirlpool model fridge did you replace your Norcold? My problem is that I have the furnace under the Norcold 1200 and that reduces the height I can install. Not sure of your coach, but if it is only a 1/2 inch difference it may be able to work.
tropical36 wrote:
its a gas motorhome so the door is in the middle of coachallbrandauto wrote:
I have a 2007 Fleetwood bounder going to install Samsung residential refridgerator with doors off measures 24 5/16 inches my door opening on motorhome is 24 1/2 anybody tried this going thru the door
Is the passenger side window not an option, before proceeding any further?
If you must go through the door, be sure to cover the dash area with some quilts or other soft material. - tropical36Explorer
If you must go through the door, be sure to cover the dash area with some quilts or other soft material. - Executive45Explorer IIIIMO, you'll have more trouble trying to get the 1200 OUT than you will getting the 197 IN. I went thru the emergency window on the side of the coach. 1200 came out the same way. I would have had to remove the passenger seat and it just seemed easier to slide it in thru the window. Pull the two handles and the window comes out easily....Dennis
38,774 PostsLatest Activity: Apr 26, 2026
