allbrandauto wrote:
looking to install Samsung 17.5 residential refrigerator in my class a dimension on fridge  is 24 and 5/16 door on motorhome is 24 7/16 has anybody bought this unit threw door and what inverter with transfer switch do I need
Can't help you with the doorway, but even a 400watt mod sinewave will do the job. However you may need a pure sinewave inverter if you're going to be running fancy electronic ice makers and such.
I'm using a 1100 at present and have made a pot of coffee with it, on just two 6v batteries, but that pretty much bleeds them dry if you've been watching TV all night long and you don't start your engine. Can't run a fridge all night on two batteries either, in most cases, but I like running on electric, going down the road and whether or not, the genset is running or not.
I also rigged up a relay for auto transfer and made it a plug and play model, by putting it in a box with a duplex outlet and then two cords with a plug on each end. One for shore power and one for the inverter, which I mounted in a separate bay and then ran a few outlets here and there inside, along with one behind the fridge.
