drifterpilot
Oct 01, 2015Explorer
Ivylog wrote:
A 197 uses DC compressor so you do not need a PSW inverter. Use your 1750 and add a transfer switch if it doesn't have one. For overnight you do not need more batteries but crank the generator to make coffee in the morning.
I need someone to explain "adding a transfer switch". What does it do and how is it "wired" in?
Also, I inquired that if I was to install another inverter, what would be minimum wattage inverter that would handle most, if not all, the potential refrigerators?
I am not concerned of doing anything that would affect resale value.
Thanks
38,766 PostsLatest Activity: Jan 10, 2026
