Ivylog
Aug 12, 2015Explorer III
I put in a 1000W PSW inverter on a new 500 AH battery bank with a separate 100A charger and a separate transfer switch. Like Don I have three choices of power to the refer. I also added cable with a 200 amp switch from my house batteries to the new battery bank so the alternator will charge the refers batteries (8 amps) while on the road.
I went a little larger on the inverter than necessary because I added a outlet to power the Sat dish and DVR so it will record the shows I like and not take 10 minutes to power up after shutting the main 2000W inverter off when I leave the coach. My DIY refer install is here.
