- theoldwizard1Explorer II
Huntindog wrote:
Nope. Lots of others here on this forum have posted similar results over the years. If you want a higher charge rate, you need to run thicker wiring.
Thicker wire helps, but you will STILL NOT BE ABLE TO RECHARGE AN RV BATTERY BANK JUST BY DRIVING !
Read this about DC-DC charging while you are driving - HuntindogExplorer
time2roll wrote:
Nope. Lots of others here on this forum have posted similar results over the years. If you want a higher charge rate, you need to run thicker wiring.. Not the easiest project, and not cheap either. The thick wiring can be hard to route to the rear of the TV, and the length will set you back $$$.Huntindog wrote:
Something is wrong with your connection or the battery was near full charge.
Wizard was recommending NOT running the fridge while underway.
And besides, depending on what the draw is, the truck may not keep the battery charged up. Most TVs really just trickle charge the TT batteries. The issue is the size of the charge line more than the altenater output. I once measured it on one of my vehicles and got 1.6 amps!
Truck should easily keep the fridge running between pedestals... even stopping for fuel or lunch. OK maybe the battery will be a little low upon arrival and then you plug in. That is what the trailer battery is for.
Some here HAVE done it though with good results.
Myself, I looked at what was involved and decided to take another path. - mike77leprechauExplorer
APT wrote:
That's a lot of trailer for your truck.
Truck should easily keep the fridge running between pedestals... even stopping for fuel or lunch. OK maybe the battery will be a little low upon arrival and then you plug in. That is what the trailer battery is for.- theoldwizard1Explorer II
Any decent householfd refrigerator should hold temperature for 8 hour IF YOU DO NOT OPEN THE DOOR !dodge guy wrote:
... I think for most of us using a residential fridge and starting with a fully charged battery it will work just fine, and even better with 2 batteries. And the truck will keep it alive long enough till you plug in at the next stop. And to really extend it with no worries you could run a good solar panel.
Concur, but it depends. What voltage does your inverter shutdown at, what voltage is delivered from the TV to the RV batteries/inverter and will your inverter automatically restart after a low voltage shutdown.
If you are dry camping and do not want to run your generator the read this about DC-DC charging while you are driving. - APTExplorerThat's a lot of trailer for your truck.
atreis wrote:
I would hope being factory installed they took this into consideration but the rv industry doesn't have a good track record at thinking things like this through lol
Just a point .. When selecting an inverter you need to consider the startup load for the compressor, not the runtime load. If you size the inverter for the run load, it likely won't be able to start running the fridge. (Startup load on a compressor is quite a lot higher than the run load.) Most fridge's don't provide this information, but 4-5x is usually sufficient. - atreisExplorerJust a point .. When selecting an inverter you need to consider the startup load for the compressor, not the runtime load. If you size the inverter for the run load, it likely won't be able to start running the fridge. (Startup load on a compressor is quite a lot higher than the run load.) Most fridge's don't provide this information, but 4-5x is usually sufficient.
- dodge_guyExplorer II
Huntindog wrote:
dodge guy wrote:
Wizard was recommending NOT running the fridge while underway.Huntindog wrote:
theoldwizard1 wrote:
This won't work where it is really hot.
I don't own a rig like that, but to preserve battery power, I would turn the refrigerator off while driving. If the door is not opened it will be fine for 12 hours or more.
AZ @ 115 will cook everything in the fridge pretty fast.
And the truck will keep the trailer battery from draining while on the road!
Right, but I think for most of us using a residential fridge and starting with a fully charged battery it will work just fine, and even better with 2 batteries. And the truck will keep it alive long enough till you plug in at the next stop. And to really extend it with no worries you could run a good solar panel. - HuntindogExplorer
44,068 PostsLatest Activity: Jun 05, 2026
