tropical36's avatar
tropical36
Residential vs Repair RV Fridge
Another problem here and found out on the land yacht's maiden voyage that the 4 door Norcold in never cold and now using the freezer area for the fridge.
So, I know this has been around a number of times
and have even commented on the numerous threads, myself, but there may possibly be another problem to contend with here.
We're at LazyDays for the weekend and more info mostly I ask at the expert desk in the store here, about their labor and procedure for replacing the Fridge with whatever. He says that firstly, the windshield must be removed for getting it out and getting the other in and they will undoubtedly break this $3K windshield in the process.
I find that hard to believe for a given an something the customer will be stuck with.
Now after taking some measurements with the coach entry door removed it's 27" and with some rough measurements of the fridge, I can't see where it can be more than 23" deep max., so I don't get where this guy is coming from.
Anyway, if anyone knows of someone and in SW Florida or elsewhere, please advise. I may be able to do this myself with a little help, even at my age, but need to explore all these possibilities first.
Also where are those that are replacing just the cooling units and especially the Amish type, getting this done?
  • I replaced the cooling unit when mine failed with the Amish one. While the result was originally satisfactory the performance of the Norcold just didn't match up with my expectations. When the ice maker failed, I yanked it, gave it to a friend and went with the Samsung. I'm in my third year with it and am totally satisfied. We are full timers so it gets used all the time. Freezer is at -2 and box is at 38 constantly. I installed it myself but had help in bringing it into the coach. We removed the living room emergency window and brought it in thru the side. Removed the Norcold the same way....Dennis
    Samsung Install
  • I like the LP option for dry camping and wanted to retain that option. So.... I installed the Amish unit and am happy with the results. No added batteries or solar to run a res fridge when boondocking. About $140 including new fans and the ARP backup controller. Not a bad job to tackle if you are able. Good luck with whatever you decide.
