femailyetti
Nov 26, 2016Explorer
This is a picture of the bracket that is used to adjust the tension on the compressor. Note the long bolt and nut. The nut welded to the bracket has been drilled out, and this long bolt used to hold the bracket in place. A shorter bolt, with a lock nut, will be used on reassembly.
