femailyetti
Nov 30, 2016Explorer
After you get the AC compressor off, you can see the top bolt used to adjust the belt tension. there are two more lower then tis tat must come off. If you had a lift you could probably get to it with out taking the compressor off.
38,780 PostsLatest Activity: Aug 05, 2026
