femailyetti
Dec 06, 2016Explorer
After you remove the four bolts, two on top and two on the bottom, of each fan assembly holding the fans to the bracket, and fish the wires out the grommet, you see this on the passenger side. These two brackets on this side will have to be removed to get of the AC coil unit.
The nipple, in the upper left of the picture, is the radiator recovery hose mounting point. The hose hanging in the breeze is from when I cut it off the dryer
38,780 PostsLatest Activity: Aug 05, 2026
