femailyetti
Dec 16, 2016Explorer
The Drivers side tire is removed , and you can get to this fitting that also goes to the trans. if you look at the bottom of the shot, you can see that they attached to a rubber lines, remove both of the clamp. The fitting was to rusty to be removed at this time.
The drain fitting is also visible in this shot. it was so rusty it would not move
38,780 PostsLatest Activity: Aug 05, 2026
