femailyetti
Dec 16, 2016Explorer
Snake your body up in the drives side tire well, with the tire off, and you can take of these two bolts to the radiator mounting bracket. There is two on the passenger side that you get to from the front, that need to come off. There is also one on the upper drivers side, you get to from the front on that needs to come off, then you can take the mounts apart and pull the radiator out the front YAY YAY.
38,780 PostsLatest Activity: Aug 05, 2026
