femailyetti
Dec 22, 2016Explorer
On the passenger side, this voltage cable runs over the oil lines, that ran to the cooler on the passenger side of the radiator.
you can see the head of the bolt that has a 3/4 in nut on the other side that must be removed in this picture. There is another one of these bolts and nut on the drivers side.
There are two of the little metal clips that stick out on the bottom that hold the fan shroud, one of these is visible here.
38,780 PostsLatest Activity: Aug 05, 2026
