femailyetti
Jan 23, 2017Explorer
The amount of space needed for clearance would have caused the bottom two bolts, that go through the oil pan to the cover, not to line up if I installed a spacer, I had some aluminum plate that I tried to do a quick can I be cheap test with. the bottom bolts would not fit into the cover when I tried it. I did try smashing the cover with some body hammers, but it bent the mounting service to bad. "its only money" seems to be the attitude I have come to develop in this project.
38,780 PostsLatest Activity: Aug 05, 2026
