femailyetti
Feb 19, 2017Explorer
I test fit the steering and brake pump to see if the part I came up with is a Go. They did not have the exact one I took off. the Hoses are slightly different on this model.
With the pump pulled all the way in it has about .40 inch before it his the header bolt. The part where the return clamp and hose go looks like it should not be a problem. It has two returns. I did not get a real good shot of the bottom line. The bottom return line is not in the way, or have any clearance problems at full tilt forward or backward.
38,780 PostsLatest Activity: Aug 05, 2026
