femailyetti
Feb 19, 2017Explorer
On the top, with it all the way out, there is a clearance problem. It should never be this far out, so its a go. The bolt that is causing the problem holds the AC bracket. it will be in about .75 inch when holding the part.
I looked at the pictures of it before it came apart on page 5, and page 7. It seems I may need to fabricate some modification in the reservoir to pump hose. It is not a pressure line so a little creativity should solve the problem and keep it out of the way of the belts.
38,780 PostsLatest Activity: Aug 05, 2026
