femailyetti
Apr 09, 2017Explorer
If you take of the far left bolt to the fan shroud, move the cruise control out of they way with one hand, pull the canvas out of the way,lay you belly on the air cleaner, twist you hand to push on they hose, slide the clamp over the hose, while bending you fingers in positions they don't want to go, turn the clamp tight 1/4 turn at a time with this tool to tighten the clamp.
38,780 PostsLatest Activity: Aug 05, 2026
