femailyetti
May 01, 2017Explorer
By making the mounting hole bigger, grinding the tab on the upper left side down, and making the U shaped part a little wider, the bracket was ready. The Throttle pin was also ground down on one side so this bracket will fit around it.
This is the final product needed for the throttle assembly to work.
38,780 PostsLatest Activity: Aug 05, 2026
