femailyetti
May 07, 2017Explorer
I jest set the carb down to see what was fitting correct. I had to apply some hits to the egr valve to get the float bowls to clear properly. The throttle assembly works as assembled. Now to fabricate the vacuum lines. and Fule line rough in.
Getting the nuts tight on this thing is going to be a pain.
38,780 PostsLatest Activity: Aug 05, 2026
