femailyetti
May 11, 2017Explorer
Traded the old Rochester carb for the rest of the pieces I need to finish the cold air ducting to the Air cleaner. I had the middle hose part of it when I got the Project.
I needed the duct, The ram, and the 45 degree bent part to run it to the grill from just over the radiator. I am Going to make a bracket to mount it to the grill so it gets cold air directly from the front of the grill. The other outlet of the front ram assembly is going to be ducted to supply cold air to the area where the oil cooler is mounted.
38,780 PostsLatest Activity: Aug 05, 2026
