femailyetti
Feb 05, 2018Explorer
Then you can take the mounts, and set them down so you can use a sharoe to show where you need to bolt them. You remove the self leveling with a razor knife so it sits level, and slightly bend the bracket so its sits correctly. This get every thing aligned so you can drill the holes for the bolts.
