femailyetti
Apr 05, 2021Explorer
I went to start the old thing so I could mow. After trouble shooting it to a problem with no fuel, we removed the gas tank. It has eight bolts holding the tank up. There are three fuel lines on the top, plus the filler, and vent hose you have to remove. you can get it out with out jacking the beast up. There is also a pressure regulator mounted to the frame we took off, so we can replace all the old rubber parts when we are doing the job.
