femailyetti
Apr 05, 2021Explorer
Here is a close up of the fuel ports on the top of the tank. If you tap on the ring, you can remove the pump unit from the tank. The one with the fitting on it goes to the regulator. One labeled thre goes to the return line, and the other is for the evaporation pollution control unit that has been removed.
