femailyetti
Apr 05, 2021Explorer
I am going to move the regulator to the front of the thing. this is to replace the regulator, the 5/16 goes to the fuel pump hose that I cut the fitting off.
The 1/2 goes to the lines running down the side of the frame to the front. This hose bib was obtained by removing it from the old original regulator, I cleaned it with a wire brush on a Dremil tool.
The plugged off part is for use if I need another line later. If I ever get another generator that just sits outside of the camper, I plan on running a line from this port to the generator. That way I don't have to get up in the middle of the night, because it runs out of gas.
