fulltimin
Apr 06, 2021Nomad
I am curious. On your fuel tank, the 3 lines are already accounted for.
Mine has no fuel pump in the tank as it is a carb version, and not fuel injected.
The fuel pump is mounted on the engine, and has a return line toj the tank.
My tank also has a line that used to go to the generator, and the end of the tube was not on the bottom, but up about 1.5 inches or so, so the generator could not drain the tank, and then the moho would have no gas to start.
How is your generator fueled?
