jeffengle
Mar 20, 2014Explorer
It is a problem. I worked for a company that had shuttle buses with the same size tires & wheels & twice after the summer tires were changed to winter tires the rear wheels fell off & sheared off the wheel studs. I complained to the tire company that they did not properly torque the wheels. I saw that they used an impact gun , followed up with a torque wrench, but the torque wrench only showed that the torque was up to a value & not the actual torque. For instance if the impact wrench tightened to 170lbs, and the torque value is 140lbs, it is over torqued. It is very important.
38,776 PostsLatest Activity: May 15, 2026
