dougrainer
Jun 02, 2020Nomad
MountainAir05 wrote:
The vent is for the heater, but it could be drawing air from the AC return and that air is hot from the basement. In other words its sucking air from the basement.
2000 Bounder would not have AIR or AC return or ducts in the floor. The Roof AC's just recycle the existing air inside the RV. BUT, when you have various holes in the floor that go into the basement, it will draw up that warmer air. You need to seal the water line and P trap assbly cut outs under the shower with spray foam or just stuff fiberglass insulation in the access hole. Usually, that "vent" is an access cover for getting to the Shower drain plumbing. Doug
38,782 PostsLatest Activity: Sep 20, 2026
