ScottG
Jun 02, 2017Nomad
Go to youtube and looks for awning replacement video's.
Rewiding the springs isn't hard but can be dangerous. Make sure you head is not over the tool you use to grip the shaft. If it slips out of your hand the centrifugal force may launch it into you.
You will need to find the number of turns for your length of awning. It's not an exact science and if your awning is older and the spring isn't as tight as it once was, you can add 1, 2 or even three extra turns to it.
My awning is 17' and IIRC, called for 13 turns. It worked a lot better with 15 turns.
38,782 PostsLatest Activity: Sep 10, 2026
